Installation & Licensing
Lmtool configuratioon for multiple vendors showing eroor
5 REPLIES 5
jawad18
401 Views, 5 Replies
Dear
We have purchased a new AUTOCAD DESIGN 2015.NLM.We installed in one server.That server is already having another server license.So i configured LMTOOLS for AUTOCAD and when performing the status enquiry it is reading the OTHER SOFTWARE LICENSE.
Please let me know the solution as early
5 REPLIES 5
chenshif
in reply to: jawad18
Hi
In the LMTOOLS "Config Services" tab, change the "Service Name" textbox to your new service, in this case Autodesk.
Fill in the consecutive paths in the textboxes below that, and click "Save Service". Then start the Service from the "Start/Stop/Reread" tab.
Hope this helps,
Chen
OpenLM
jawad18
in reply to: chenshif
Dear
Yup I tried that.But still not working.
Also now it is showing VD is starting and getting errror.
Could you please let me know the solution ??
Thnaks
chenshif
I need more information:
What exactly is "Not working" ?
What do you see ?
What error message do you get ?
Chen
Openlm.com
jawad18
Dear
Error -15.57 ?A LICENSE CANNOT BE OBTAINED THROUGH NLM.I ?tried to run the AUTOCAD 2015 through client so I get this error.
I tried to solve with all solution from AUTODESK but still the problem persist
TravisNave
This is a common issue when there are other 3rd party vendors that use FlexLM.  However, you can easily combine them and everything will work great.
For the best method to properly combine your license files, please read my entire thread here and choose the method that best fits your needs:
http://forums.autodesk.com/t5/Installation-Licensing/Combining-License-Files-for-Subscription-and-No...
That should point you in the right direction.
Autodesk Forums:
Administrator Productivity
