I'm having trouble getting LMTOOLS to work for Sketchbook Pro 2015.
I've used LMTOOLS before on a different VM so I'm fairly familiar with navigating it and getting it to work.
Under the "Config Services" tab, I have added the path to lmgrd.exe
and the path to the license file I downloaded from autodesk.com
After I "Start Server" under the "Start/Stop/Reread" tab,
then "Perform Status Enquiry" it gives me "FlexNet Licensing error:-13,66"
"Error getting status: No SERVER lines in license file."
So I add the SERVER line like i've seen on other license files (like Kyeyshot & PADS).
SERVER ServerName ServerMacAddress PortNumber
And then I get this error -15,570
"lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed."
EDIT: I've followed the advice here and it still doesn't work.
Any help is appreciated. Cheers.
did you generate a license file with the correct server name and MAC address?
DarrenP
So the problem is I was using the key.txt rather than a license file.
I was able to generate that here: http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
