We have about 5 users that we want to upgrade from Autocad 2005 to Autocad 2010 or 2011. I would like to setup a NLM to manage the 5 licenses but it is difficult trying to figure out what I actually need to buy as far as the software and licensing goes. Do I need to buy a full version for each person? Do I just need to buy 1 full version and then buy 4 other types of add-on licenses? How does the NLM know how many licenses it has to use? Any help would be appreciated.
Solved by TravisNave. Go to Solution.
Generally speaking, when you buy a 5-seat network license you are issued your product with a serial number that is good for 5 seats. The network license file that gets created for you on that serial number is set for 5 seats. You can install an infinite number of network client installations that point to the NLM, but only 5 will launch at any given time. The NLM will run on nearly any computer as it has very little overhead. I joke that you can run it on an Etch-a-Sketch.
I'd be happy to field any of your questions.
