I'm getting this error (see attachment) trying to run Maya 2014. I used the student version and activated my account. Thank for any help or suggestions.
Solved by jessica.t. Go to Solution.
Hi @wenos and welcome to the Autodesk Community!
What operating system are you working with today? See this Autodesk Solution if you are on Mavericks. Please also be sure to check the system requirements as Maya 2014 is not compatible with Yosemite. If problem persist please reply with further information on your system specifications.
Thank you!
Hi Jessica, where on my profile do i find
Products & Services section
Tatjana
@Anonymous
When you log in Autodesk Account, click ACCOUNT tab on the top the page and then you will find Products & Services section on the left.
