Installation & Licensing
Licensing error // Autodesk Maya 2013
4 REPLIES 4
784 Views, 4 Replies
Hello ,I was Thailand.I use Googel Translate.
Help me please.I have a serail number (Student) but i it's Licensing error(License not obtained).
I want this program so much.
I discover many solution but it not works.
1. Delete the file Maya.env file which may be corrupt / preventing the program from functioning. After doing so and upon first run, a new Maya.env file will be generated.
1: Pull up run and type in services.msc
2: Click on the standard tab at the bottom.
3: Find FLEXnet licensing service.
4: Right click on it and press properties.
5: Make the start-up type Automatic.
6: Under “service Status”, press start.
(Not work)
2.Reinstall (Not work)
Licensing Error
Unable to initialize adlm.
Internal Error Message: <Unable to find security rumtime.>
Error Code : <1>
4 REPLIES 4
This photo is a problem ):.
philip.s
Hello again!
Can you please delete all Autodesk licensing info from a system by removing the following:
Vista, Windows 7, or Windows 8:
C:\ProgramData\FLEXnet\adskflex_*.data
C:\ProgramData\FLEXnet\adskflex_*.data.backup
Windows XP:
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data.backup
Mac:
/Library/Preferences/FLEXnet Publisher/FLEXnet/adskflex_*.data
/Library/Preferences/FLEXnet Publisher/FLEXnet/adskflex_*.data_backup
In the event a reactivation limit error message occurs, please contact our License Assistance Team for direct support.
Any luck?
in reply to: philip.s
I don't know my request code because i can't launch the Product Activation Wizard
(Licensing error)
philip.s
Did removing the flexnet folder have any impact? Same error?
Administrator Productivity
