Installation & Licensing
Licensing Error[-5.412.0]
15 REPLIES 15
Message 1 of 16
selcukterkan
2455 Views, 15 Replies
Dear Friends,
Autodesk gave us “Education Master Suite 2014 “ for academic usage. As you can see on attached pic  “Education Master Suite 2014 “ is already activated on our licensing web site. I received a license file for this product and installed it on our license server. And “Autodesk Simulation CFD 2014 (English) 64-Bit “ seems like it is included in the package. But when we install and run the program I became license error “ Error[-5.412.0] “. It acts like the program is not included in the “Education Master Suite 2014 “ package. But it is. Or it should be. May be the program is forgatten to be added in the license file. The other programs from the same package works fine. Do you have any idea what could be the reason for that?
Thank you & best regards
Cuneyt Cecen
15 REPLIES 15
Message 2 of 16
Jon.Wilde
in reply to: selcukterkan
I think the best thing to do would be to get in touch with the team here, they should be able to assist you with the licence.
Kind regards,
Jon
Message 3 of 16
selcukterkan
Dear Jon,
I already try that link. The guys up there couldn't solve my issue 😞
They redirect me to the discussion groups...
Cuneyt
Message 4 of 16
Jon.Wilde
That is a surprise. Do you get any other text with the error or just a number?
Kind regards,
Jon
Tags (2)
Message 5 of 16
selcukterkan
Dear Jon,
I’m sure that I installed the license file corectly on our license server.
The other programs from the same package works but “Autodesk Simulation CFD 2014” program doesn’t.
I get the this error lines on log file :
4668 2013/08/16 16:05:09 Reason=Fatal error
4668 2013/08/16 16:05:09 ComputerName=ABSTNCCECE8
4668 2013/08/16 16:05:09 OS=6.2.9200.
4668 2013/08/16 16:05:09 File=AdlmIntNWFBLicense.cpp,Line=782
4668 2013/08/16 16:05:09 VendorID=3 [FLEXLM-NW]
4668 2013/08/16 16:05:09 VendorError=-5 [No such feature exists.]
4668 2013/08/16 16:05:09 FLEXLM-NW=v11.11.0.0 build 106800 x64_n6
4668 2013/08/16 16:05:12 Reason=Fatal error
4668 2013/08/16 16:05:12 ComputerName=ABSTNCCECE8
4668 2013/08/16 16:05:12 OS=6.2.9200.
4668 2013/08/16 16:05:12 File=AdlmIntNWFBLicense.cpp,Line=765
4668 2013/08/16 16:05:12 AdlmIntError=20 [License check out failed]
It seems like right license codes for “Autodesk Simulation CFD 2014” are not included in the license file.
Below you can see our license package coverage (I removed the serials). As you can see package is already activated.
Education Master Suite 2014 Autodesk 3ds Max Design 2014 (English) 64-Bit
Autodesk Alias Design 2014 (English) 32-Bit
Autodesk Alias Design 2014 (English) 64-Bit
Autodesk Alias Design 2014 (English) Mac OS X
Autodesk AutoCAD 2014 (English) 32-Bit
Autodesk AutoCAD 2014 (English) 64-Bit
Autodesk AutoCAD Architecture 2014 (English) 32-Bit
Autodesk AutoCAD Architecture 2014 (English) 64-Bit
Autodesk AutoCAD Civil 3D 2014 (English) 64-Bit
Autodesk AutoCAD Electrical 2014 (English) 32-Bit
Autodesk AutoCAD Electrical 2014 (English) 64-Bit
Autodesk AutoCAD Map 3D 2014 (English) 32-Bit
Autodesk AutoCAD Map 3D 2014 (English) 64-Bit
Autodesk AutoCAD Mechanical 2014 (English) 32-Bit
Autodesk AutoCAD Mechanical 2014 (English) 64-Bit
Autodesk AutoCAD MEP 2014 (English) 32-Bit
Autodesk AutoCAD MEP 2014 (English) 64-Bit
Autodesk AutoCAD Plant 3D 2014 (English) 32-Bit
Autodesk AutoCAD Plant 3D 2014 (English) 64-Bit
Autodesk AutoCAD Raster Design 2014 (English) 32-Bit
Autodesk AutoCAD Raster Design 2014 (English) 64-Bit
Autodesk AutoCAD Structural Detailing 2014 (English) 32-Bit
Autodesk AutoCAD Structural Detailing 2014 (English) 64-Bit
Autodesk AutoCAD Utility Design 2014 (English) 32-Bit
Autodesk AutoCAD Utility Design 2014 (English) 64-Bit
Autodesk InfraWorks 2014 (English) 64-Bit
Autodesk Inventor Professional 2014 (English) 32-Bit
Autodesk Inventor Professional 2014 (English) 64-Bit
Autodesk Mudbox 2014 (English) 64-bit
Autodesk Mudbox 2014 (English) Mac OS X
Autodesk Navisworks Manage 2014 (English) 32/64-Bit
Autodesk Revit 2014 (English) 32/64-Bit
Autodesk Robot Structural Analysis Professional 2014 (English) 32/64-Bit
Autodesk Showcase 2014 (English) 32-Bit
Autodesk Showcase 2014 (English) 64-Bit
Autodesk Simulation Mechanical 2014 (English) 32-Bit
Autodesk Simulation Mechanical 2014 (English) 64-Bit
Autodesk Simulation Moldflow Adviser Ultimate 2014 (English) 32-Bit
Autodesk Simulation Moldflow Adviser Ultimate 2014 (English) 64-Bit
Serial Number         Number of Seats       CSN         Registration Date       Expiration Date
 xxx-xxxxxxxxxxxx         125                               xxxxxx       2013-08-05                    2016-08-04
Thanks for your help.
Best Regards
Cuneyt
Message 6 of 16
Jon.Wilde
I think the issue might be the licence as you say. CFD is broken into sections, it looks as though you have a solver licence but not interface licence (Design Study Manager).
What I suggest we do in the first instance is move this thread to the Installation and Licencing page - if you have no luck there feel free to IM me and I will try to help you further.
I hope that is OK.
Kind regards,
Jon
Tags (1)
Message 7 of 16
selcukterkan
Ok Jon,
Thanks for your kind help..
Let's try our change there...
Message 8 of 16
TravisNave
The -5 definitely means that it cannot find the product licensed.  If you have a combined license, it can cause it. It can also happen on a corrupted CascadeInfo.cas file.
Go to C:\ProgramData\Autodesk\Adlm and rename the CascadeInfo.cas file and try to relaunch the program.  Also post your adlm log file and copy/paste your status enquiry from LMTOOLS as well as the debug.log file from there as well.  Should be defeatable.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 9 of 16
selcukterkan
Dear Travis,
I already tried to rename cascadeinfo.cas file. It dosen't change anything.
Here is our server's status enquiry :
License server status: 27002@ABIMSLSNS
License file(s) on ABIMSLSNS: C:\Program Files\Autodesk Network License Manager\License\ABIMSLSNS.lic:
ABIMSLSNS: license server UP (MASTER) v11.4
Vendor daemon status (on ABIMSLSNS):
  adskflex: UP v10.8
Feature usage info:
Users of 85973EMS_2013_0F:  (Total of 125 licenses issued;  Total of 1 license in use)
  "85973EMS_2013_0F" v1.000, vendor: adskflex
  floating license
    n.saatcioglu AMIMDASAATC AMIMDASAATC (v1.0) (ABIMSLSNS/27002 201), start Wed 9/4 14:09
Users of 85926ENCSU_2013_0F:  (Total of 125 licenses issued;  Total of 0 licenses in use)
Users of 85857MAYAMMR1_2013_0F:  (Total of 625 licenses issued;  Total of 0 licenses in use)
Users of 85934SFTIMSIB_2013_0F:  (Total of 625 licenses issued;  Total of 0 licenses in use)
Users of 86043TRTLPB_2013_0F:  (Total of 625 licenses issued;  Total of 0 licenses in use)
Users of 86087ENCSU_2014_0F:  (Total of 125 licenses issued;  Total of 0 licenses in use)
Users of 86058MAYAMMR1_2014_0F:  (Total of 625 licenses issued;  Total of 0 licenses in use)
Users of 86090SFTIMSIB_2014_0F:  (Total of 625 licenses issued;  Total of 0 licenses in use)
Users of 86095TRTLPB_2014_0F:  (Total of 625 licenses issued;  Total of 0 licenses in use)
Users of 86112EMS_2014_0F:  (Total of 125 licenses issued;  Total of 0 licenses in use)
 Debug Log:
 14:09:32 (lmgrd) -----------------------------------------------
14:09:32 (lmgrd)   Please Note:
14:09:32 (lmgrd)
14:09:32 (lmgrd)   This log is intended for debug purposes only.
14:09:32 (lmgrd)   In order to capture accurate license
14:09:32 (lmgrd)   usage data into an organized repository,
14:09:32 (lmgrd)   please enable report logging. Use Macrovision's
14:09:32 (lmgrd)   software license administration  solution,
14:09:32 (lmgrd)   FLEXnet Manager, to  readily gain visibility
14:09:32 (lmgrd)   into license usage data and to create
14:09:32 (lmgrd)   insightful reports on critical information like
14:09:32 (lmgrd)   license availability and usage. FLEXnet Manager
14:09:32 (lmgrd)   can be fully automated to run these reports on
14:09:32 (lmgrd)   schedule and can be used to track license
14:09:32 (lmgrd)   servers and usage across a heterogeneous
14:09:32 (lmgrd)   network of servers including Windows NT, Linux
14:09:32 (lmgrd)   and UNIX. Contact Macrovision at
14:09:32 (lmgrd)   www.macrovision.com for more details on how to
14:09:32 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
14:09:32 (lmgrd)   for your enterprise.
14:09:32 (lmgrd)
14:09:32 (lmgrd)
14:09:32 (lmgrd)
14:09:32 (lmgrd) pid 5032
14:09:32 (lmgrd) Detecting other license server manager (lmgrd) processes...
14:09:32 (lmgrd) Done rereading
14:09:32 (lmgrd) FLEXnet Licensing (v11.4.0.0 build 31341) started on ABIMSLSNS (IBM PC) (9/4/2013)
14:09:32 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
14:09:32 (lmgrd) US Patents 5,390,297 and 5,671,412.
14:09:32 (lmgrd) World Wide Web:  http://www.macrovision.com
14:09:32 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\License\ABIMSLSNS.lic
14:09:32 (lmgrd) lmgrd tcp-port 27002
14:09:32 (lmgrd) Starting vendor daemons ...
14:09:32 (lmgrd) Starting vendor daemon at port 2080
14:09:32 (lmgrd) Using vendor daemon port 2080 specified in license file
14:09:32 (lmgrd) Started adskflex (pid 5044)
14:09:32 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
14:09:32 (adskflex) lmgrd version 11.4, adskflex version 10.8
14:09:32 (adskflex) Server started on ABIMSLSNS for: 85973EMS_2013_0F
14:09:32 (adskflex) 85926ENCSU_2013_0F 85857MAYAMMR1_2013_0F 85934SFTIMSIB_2013_0F
14:09:32 (adskflex) 86043TRTLPB_2013_0F 86087ENCSU_2014_0F 86058MAYAMMR1_2014_0F
14:09:32 (adskflex) 86090SFTIMSIB_2014_0F 86095TRTLPB_2014_0F 86112EMS_2014_0F
14:09:32 (lmgrd) adskflex using TCP-port 2080
14:09:40 (adskflex) TCP_NODELAY NOT enabled
14:09:40 (adskflex) OUT: "85973EMS_2013_0F" a.k.terlemez@MSL-03
14:09:48 (adskflex) OUT: "85973EMS_2013_0F" n.saatcioglu@AMIMDASAATC
14:10:13 (adskflex) OUT: "85973EMS_2013_0F" h.duyar@ASTFDOGUZE
14:10:24 (adskflex) OUT: "85973EMS_2013_0F" o.guzelci@MSL-01
14:16:19 (adskflex) OUT: "86112EMS_2014_0F" c.cecen@abstnccece8
14:18:43 (adskflex) IN: "86112EMS_2014_0F" c.cecen@abstnccece8
14:45:25 (adskflex) OUT: "85973EMS_2013_0F" meltem.aydin@AYPIDMAYDI
14:45:39 (adskflex) IN: "85973EMS_2013_0F" meltem.aydin@AYPIDMAYDI
14:47:23 (adskflex) OUT: "85973EMS_2013_0F" a.ozcan@AYPIDSYASSA
14:48:30 (adskflex) OUT: "85973EMS_2013_0F" adindar@AMMFDADIND
14:48:31 (adskflex) OUT: "85973EMS_2013_0F" meltem.aydin@AYPIDMAYDI
14:50:23 (adskflex) IN: "85973EMS_2013_0F" adindar@AMMFDADIND
15:46:23 (adskflex) IN: "85973EMS_2013_0F" h.duyar@ASTFDOGUZE
15:46:56 (adskflex) OUT: "85973EMS_2013_0F" g.arik@AMMFDGARIK1
15:49:23 (adskflex) IN: "85973EMS_2013_0F" a.ozcan@AYPIDSYASSA
15:56:31 (adskflex) OUT: "85973EMS_2013_0F" i.tekin@AMMFDITEKI
16:03:00 (adskflex) IN: "85973EMS_2013_0F" i.tekin@AMMFDITEKI
16:29:24 (adskflex) OUT: "85973EMS_2013_0F" a.ozcan@AYPIDSYASSA
16:30:20 (adskflex) IN: "85973EMS_2013_0F" g.arik@AMMFDGARIK1
16:34:39 (adskflex) IN: "85973EMS_2013_0F" meltem.aydin@AYPIDMAYDI
17:15:28 (adskflex) IN: "85973EMS_2013_0F" o.guzelci@MSL-01
17:33:26 (adskflex) IN: "85973EMS_2013_0F" a.ozcan@AYPIDSYASSA
18:09:55 (adskflex) IN: "85973EMS_2013_0F" a.k.terlemez@MSL-03
ADLM.LOG:
9076 2013/09/04 18:35:37 Reason=Fatal error
9076 2013/09/04 18:35:37 ComputerName=ABSTNCCECE8
9076 2013/09/04 18:35:37 OS=6.2.9200.
9076 2013/09/04 18:35:37 File=AdlmIntNWFBLicense.cpp,Line=782
9076 2013/09/04 18:35:37 VendorID=3 [FLEXLM-NW]
9076 2013/09/04 18:35:37 VendorError=-5 [No such feature exists.]
9076 2013/09/04 18:35:37 FLEXLM-NW=v11.11.0.0 build 106800 x64_n6
9076 2013/09/04 18:35:44 Reason=Fatal error
9076 2013/09/04 18:35:44 ComputerName=ABSTNCCECE8
9076 2013/09/04 18:35:44 OS=6.2.9200.
9076 2013/09/04 18:35:44 File=AdlmIntNWFBLicense.cpp,Line=765
9076 2013/09/04 18:35:44 AdlmIntError=20 [License check out failed]
Thank you
Cuneyt
Message 10 of 16
TravisNave
I notice that your adskflex.exe vendor file is a little outdated.  You might consider upgrading it.
Are you getting this error on every Simulation you launch?  Or just one machine?
Would you be willing to PM me your LIC file?
Autodesk Forums:
Message 11 of 16
selcukterkan
in reply to: TravisNave
Hello Travis,
On different PC's we get the same result.
I send you our LIC file with PM.
Cuneyt
Message 12 of 16
TravisNave
I don't see any problem with the LIC file.  It parses fine.
CFD should cascade to the EMS 2014.  Where did you install CFD from?
Autodesk Forums:
Message 13 of 16
selcukterkan
We downloaded "Autodesk Sİmulation CFD" from academic.autodesk.com  web page.
It's under downloadable programs list.
Message 14 of 16
DarrenP
problem is does the education suite come with CFD design study license which is the user interface for CFD which is required to even open up the program
DarrenP
Message 15 of 16
dembkod
ccecen,
Hello. CFD is not part of the actual EMS printed license. So, if you have a lic with just the EMS license in it, it is not enough. You will need a license generated for the various CFD parts.
If you can access the installer from your login, I would expect you are entitled to it. You should just need to get the additional licenses. You would need an increment for CFD, CFD Design Study, and likely a solving component of some sort.
Thank you for taking part in our community!
David Dembkoski
Message 16 of 16
selcukterkan
Thank you all for kind support !!!
Cuneyt
Administrator Productivity
