Installation & Licensing
Active Member
1 Kudo
Post 11 of 16
Re: Licensing Error[-5.412.0]
09-04-2013 10:38 AM in reply to: TravisNave
Hello Travis,
On different PC's we get the same result.
I send you our LIC file with PM.
Cuneyt
893 Kudos
Post 12 of 16
09-04-2013 11:07 AM in reply to: ccecen
I don't see any problem with the LIC file.  It parses fine.
CFD should cascade to the EMS 2014.  Where did you install CFD from?
Active Member
1 Kudo
Post 13 of 16
09-04-2013 11:15 AM in reply to: TravisNave
We downloaded "Autodesk Sİmulation CFD" from academic.autodesk.com  web page.
It's under downloadable programs list.
651 Kudos
Post 14 of 16
09-04-2013 01:03 PM in reply to: ccecen
problem is does the education suite come with CFD design study license which is the user interface for CFD which is required to even open up the program
Product Support
69 Kudos
Post 15 of 16
09-04-2013 02:57 PM in reply to: ccecen
ccecen,
Hello. CFD is not part of the actual EMS printed license. So, if you have a lic with just the EMS license in it, it is not enough. You will need a license generated for the various CFD parts.
If you can access the installer from your login, I would expect you are entitled to it. You should just need to get the additional licenses. You would need an increment for CFD, CFD Design Study, and likely a solving component of some sort.
Thank you for taking part in our community!
David Dembkoski
Active Member
1 Kudo
Post 16 of 16
09-05-2013 06:31 AM in reply to: ccecen
Thank you all for kind support !!!
Cuneyt
