Installation & Licensing
Licensing error 30:failed to AdLM
1 REPLY 1
569 Views, 1 Reply
From the installation of Revit it stopped loading on my pc for no reason.
After reinstalling it twice still the same issue. when I load up revit the window opens up but this Licensing error 30:failed to AdLM appears
I ask you why this has happened and how to put this right. It is obvious a licensing issue.
My computer is windows vista and the programm is Revit 12 Architecture.
Any advice would be greatly appreciated, thank you
1 REPLY 1
philip.s
Welcome to the community Vale!
Have you tried a clean uninstall yet? If that doesn't fix it, you might want to consider looking into some common 3rd party (non-Autodesk supported) applications which were used in this forum post to resolve the same error 30:failed to AdLM.
Please accept as a solution, or reply with additional specifics if the problem persists.
Administrator Productivity
