From the installation of Revit it stopped loading on my pc for no reason.
After reinstalling it twice still the same issue. when I load up revit the window opens up but this Licensing error 30:failed to AdLM appears
I ask you why this has happened and how to put this right. It is obvious a licensing issue.
My computer is windows vista and the programm is Revit 12 Architecture.
Any advice would be greatly appreciated, thank you
Solved by philip.s. Go to Solution.
Welcome to the community Vale!
Have you tried a clean uninstall yet? If that doesn't fix it, you might want to consider looking into some common 3rd party (non-Autodesk supported) applications which were used in this forum post to resolve the same error 30:failed to AdLM.
Please accept as a solution, or reply with additional specifics if the problem persists.
