we are using these products:
DWF Composer 2.0 |
DWG to PDF Converter 2005 |
DWG TrueView 2.0 |
DWG TrueView 2009 |
on desktop machines that may be migrated from physical to VDI. Are there tech or licensing issues we need to be aware of?
Solved by TravisNave. Go to Solution.
Technically speaking, I don't think Autodesk supports those products in a virtual environment. However, per license compliance, it shouldn't be a problem if you continue to follow the EULA guidelines.
