Follow the link or read below about licenses.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=11067735&linkID=9240617
he package license file contains a set number of licenses for four different versions of your software. For example, an AutoCAD 2009 package license file will contain a set number of licenses that can be used for AutoCAD 2009, 2008, 2007 or 2006. Note: Running an instance of any one of these versions will consume one license in the package. Running more than one version, even on the same machine, will consume more than one license in the package.
If you have a 2-license package for AutoCAD 2009, the following scenarios can be expected:
Two machines running AutoCAD 2009 will consume two licenses. No licenses will be available for other users.
The same machine running AutoCAD 2008 and AutoCAD 2009 will consume two licenses. No licenses will be available for other users.
The same machine running three instances of AutoCAD 2007 will consume one license. One license will be available for other users.
Now my question,
If I have Revit Architecture suite 2010 (under subscription) license on the license manager. I have a machine with Autocad 2010 and Revit Architecture 2010. If I start both products how many licenses will be consumed?
Same machine but now with Revit Architecture 2010 and Autocad 2009. How many licenses will be consumed now?
besides the answere could you post me a link to a pdf or so where this mechanism is explained?
Thanks a lot for your effort.
