can anyone help me with this error??
"license was not obtained tried maya 2014 error 20"
Thank you,
Miguel
Solved by dembkod. Go to Solution.
Hello. We are missing a ton of useful information.
Is this new behavior?
Is this a MAC or Windows machine?
Is this a network or Standalone installation?
Have you uninstalled and reinstalled?
If this is new, and a network, do you have a network license available? Did you get a license file for the 2014 product?
If this is Windows:
We can delete the TSF.data file. It will resemble this: ADSKFLEX_NUMBERS_TSF.data. It should be located here:
Windows XP:
Documents and Settings\All Users\Application Data\FLEXnet
Vista/Windows 7:
C:\ProgramData\FLEXnet
If this is MAC
1.) Uninstall the program
2.) In Finder click Go > Go to Folder
3.) Navigate to , and delete the following folders:
/Library/Autodesk
/Library/Application Support/Autodesk
4.) Delete the ADSKFLEX files in this location:
/Library/Preferences/FlexNET Publisher/FlexNET
This may help.
Thank you for taking part in our community!
Same issue.
OS:
Windows Technical Preview, build 9860
Standalone install
Installed products:
Maya 2015
3DS Max 2015
Student license. Currently between programs at Seneca College, Toronto. Finished one Aug. 2014. Starting up again January 2015
