Installation & Licensing
LIcense was not obtained Tried Maya 2011 (657C1 2011.0.0.F), error 2
6 REPLIES 6
18070 Views, 6 Replies
Can you please explain what an "error 2" is?
Try to install 2011 as standalone on Mac OS X 10.6.2, The installation fails, I get this message:
License was not obtained
2
License method:
environment variable
MAYA_LICENSE_METHOD='standalone'
Product choice:
MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not
set
6 REPLIES 6
jekofthenew
i just try this ... http://area.autodesk.com/forum/autodesk-3ds-max/installation---hardware---os/the-software-license-ch...
and it worksssss... Thnks God ...and thanks ... "halopro77"
1: Pull up run and type in services.msc
2: Ckick on the standard tab at the bottom.
3: Find FLEXnet licensing service.
4: Right click on it and press propoties.
5: Make the start-up type Automatic.
6: Under “service Status”, press start.
if no.5 doesnt work ... change the star-up type Automatic ( Delayed Start )
that's work for meee.....
in reply to: jekofthenew
One thing to add here - if this doesn't work the first time, stop the service and delete c:\ProgramData\FLEXnet and then restart the service. That's what FINALLY got me working.
hi all its just becz we have stopped the licence from the services (msconfig > services)
to enable it just go to services , find out the above licence and start it
Hi. Thanks for the help. But is there a solution procedure for Mac OSX 10.6?
Please reply.
Johnnythaitran@gmail.com
i tried and it didnt work
Thank you very very much..
I was trying from the last one month for this error..
after all long time it is working..
Thanks...
Administrator Productivity
