There is a maximum number of times that we can transfer a license (2014 products) with the License transfer Utility?
Thanks!
Solved by philip.s. Go to Solution.
Hi Eric!
Per the License Transfer Utility FAQ, "There is no limit on how many times you can export and import your license; however, you cannot export more licenses than you actually own."
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information!
