I want to use my AutocadLT 2012 on another computer and when using the License Transfer Utility on the existing machine, an HP Desktop tower, running Windows Vista, I went into the utility, created an account with Autodesk, entered the serial number from the product case, then since I was not ready to do anything yet, I pressed "Close".
The result is that now the program loads, flashes a screen for about 0.1 seconds and dies.
Also the License Transfer Utility is no longer accessible. The folders appear cleaned out.
MY SOFTWARE IS NOW TOTALLY Wiped - nothing works at all. HELP! Re-installing ends with the same result.
Hi @ddworshak and welcome to the Autodesk Community!
According to our records your AutoCAD LT 2012 is registered and available for use. I have sent you a private message with the license information so that you can confirm you have the correct information.
Be sure to maintain the formatting when attempting to activate (no spaces, all capital letters):
Serial Number: xxx-xxxxxxx
Product Key: ABC1D
If the License Transfer Utility does not work, complete a fresh installation on the new machine by downloading AutoCAD LT 2012 from our Virtual Agent. If the problem persists please reply to this post with further details. Thanks!
