Installation & Licensing
Customer Service
71 Kudos
Post 21 of 52
Re: License Transfer Utility - Export Request Failed
04-14-2013 08:24 PM in reply to: ckteo12
Hi ckteo12,
Please Private Message me (click on my joane.bonghanoy profile name, and then "Send this user a Private Message") your Serial Number and Request Code.
Joane Bonghanoy
Member
0 Kudos
Post 22 of 52
04-16-2013 02:04 AM in reply to: joane.bonghanoy
Hi Joane,
Did you received my reply on the serial number and request code sent
yesterday? As I have not receive any reply from you, I am uncertain if
you have received the information I sent via private message to you. For
your advise please. Thanks.
Cher Kian
Disclaimer: This message (including any attachments) is for the use of
the addressee only. It may contain private proprietary or legally
privileged statements and information. No confidentiality or privilege
is waived or lost by any transmission error. If you are not the intended
receipent, please immediately delete it and all copies of it from your
system, destroy any hard copies of it and notify the sender immediately.
You must not, directly or indirectly, use, disclose, distribute, print,
copy or rely on any part of this message if you are not the intended
recipent. Any views expressed in this message (including any
attachments) are those of the individual sender and not those of any
member of the YTL Group, except where the message states otherwise and
the sender is authorized to state them to be the views of any such
entity.
177 Kudos
Post 23 of 52
04-16-2013 02:29 AM in reply to: ckteo12
hi ckteo12,
Joane is not in the office at the moment. If you would like to speed up the process, please forward the mentioned Private Message to me (click on my screenname camilo.lemos and then on Send Private Message).
Thank you,
Camilo Lemos
Member
0 Kudos
Post 24 of 52
04-16-2013 02:52 AM in reply to: camilo.lemos
Thanks Camilo,
I have sent you the info to your private message. Thanks.
Cher Kian
177 Kudos
Post 25 of 52
04-16-2013 03:37 AM in reply to: ckteo12
Hi Cher Kian,
Just replied to your private message,
Let me know if you need any more help:smileyhappy:
Camilo Lemos
Member
0 Kudos
Post 26 of 52
04-16-2013 09:59 PM in reply to: camilo.lemos
Thanks Camilo.
I have sucessfully activated the software. Thanks.
Cher Kian
New Member
0 Kudos
Post 27 of 52
05-06-2013 05:27 AM in reply to: ckteo12
I have same problem with one computer and it gives error number 1 when trying to export both licenses.
Problem is with Autodesk 3ds Max 2012 and AutoCAD Revit Architecture Suite 2010
Can I have manual deactivation also? Can I sent my license information with private message?
177 Kudos
Post 28 of 52
05-06-2013 06:04 AM in reply to: mika.tiilikka
Hi mika.tiilikka and welcome to the forums,
Please, send me your serial numbers via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) and I'll have a look at why this is happening.
Best regards,
Camilo Lemos
New Member
0 Kudos
Post 29 of 52
10-27-2013 12:10 AM in reply to: joane.bonghanoy
Hi, I've the similar problem. It said activation limit reached when I try to install my REVIT 2014 student edition on a new computer. I've uninstalled the old one already, but it still don't let me activate the program. Can you help me with that?
Customer Service
2 Kudos
Post 30 of 52
11-06-2013 02:07 PM in reply to: junxianpoon
Hi Junxian!
Are you still having issues activating your student software?
Just to explain a little, student software is only allowed one activation and any subsequent activation will produce an activation limit has been reached message. We do understand though that situations occur where reactivation is necessary such as installing it on a new computer due to the old computer having hardware issues or just wanting to upgrade.
In order to reactivate please, contact our license assistance team and provide your request code, who will then be able to generate an activation code.
Thank you for contributing to our online community!
Mike Beale
