I cannot get the License Transfer Utility to run again after I used it to put a license on my XP 64 bit machince the LTU will not come up at all and it will not alow me to return the license by any means that I have tried! Help me xxx-xxx-xxxxTxt me
Jennifer
3ds max 2010 64 bit sitting stuck on my old system
Edited by
Discussion_Admin
Try a Repair from Add and Remove Programs in the Control Panel.
We moved your post to a new topic.
the procedure failed to correct the issue, the task manager shows the LTU working but then disapears and no window is displayed for the LTU, i had called autodesk support on the phone and they said something about completely uninstalling the whole thing, gosh do i really need to wipe it? suggestions...
My next recommendation would be to check the ADLM log in:
Windows 7 or Vista:
C:\ProgramData\Autodesk\Adlm
Windows XP:
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm
Then reinstall following: http://support.autodesk.com/getdoc.asp?id=TS45252.
Autodesk would prefer that you transferred the license however you can reactivate on the new computer. Make sure you uninstall from the old computer.
Registration and Activation Contact Information:
Americas
Opening hours Monday through Friday, 8:00 AM - 8:00 PM EST
Email: authcodes@autodesk.com
Phone: toll free 800-551-1490 or 415-507-4690
Fax: 800-225-6490
Europe and Middle East
Opening hours Monday through Friday, 8:00 AM - 6:00 PM CET
Email: authcodes.neu@autodesk.com
Fax: +41 32 723 9169
Asia Pacific
Opening hours Monday through Friday, 9:00 AM - 6:00 PM Singapore Time
Email: ap.register@activation.autodesk.com
Japan
Email: japan.register@activation.autodesk.com
Fax: 03-6221-1791
Korea
Email: korea.register@activation.autodesk.com
Fax: 00798 852 1 9231
