Installation & Licensing
License Timeout
11 REPLIES 11
Message 1 of 12
1435 Views, 11 Replies
License Timeout
Hi all
In Flexlm funtion TIMEOUT can use on Autodesk Inventor
11 REPLIES 11
Message 2 of 12
To my knowledge it's not supported for Inventor.
Best Regards, Jimmy Bergmark
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) -
http://www.jtbworld.com/?/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2005 and 2006
http://www.jtbworld.com/autocad2005.htm
http://www.jtbworld.com/autocad2006.htm
"Montree Jamkrajang" wrote in message
news:4915863@discussion.autodesk.com...
Hi all
Message 3 of 12
Thank you for answer and Please Help me.
my group use Autodesk Inventor in 10Lic.
Have 15user to shuffle. sometime user exit program
License not return......why not?
FlexLM show 10Lic to use( it real use 7 - 9 lic)
Help me again
_____________________________________________________________________
"Jimmy Bergmark" wrote in message
news:4915869@discussion.autodesk.com...
Hi all
Message 4 of 12
What version of Inventor is it? What version of FlexLM?
--Cy--
Message 5 of 12
TravisNave
Just use TIMEOUTALL 1800 in an adskflex.opt file to set the timeout for all your products to 30 minutes.
Also, see my other response in your other post about the licenses being consumed. Chances are that your Inventor.exe process is not being released when the program closes. Check the Task Manager and kill it if this is the case.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 6 of 12
Autodesk Inventor V.10 and FlexLm V 10.1.5
__________________________________________________________________________
"Cy Shuster" wrote in message
news:4915981@discussion.autodesk.com...
--Cy--
Message 7 of 12
Can anyone confirm or deny that the timeout works with IV10? It has not
worked in IV9 and previous. It would be great if it worked the same way
as it does in AutoCad.
Dave
> --Cy--
Message 8 of 12
TravisNave
As far as I know. I still supply adskflex.opt files for AIS10.
Autodesk Forums:
Message 9 of 12
It works for autocad from the AIS9, but not for inventor. Below is a
snip of my log file. All the "inactive" entrys are someone using
autocad. The inventor sessions can be left up for hours (TIMEOUTALL 900)
without timing out.
14:48:13 (adskflex) OUT: "46400INVBUN_9_0F" nicholascg@work-32
15:05:18 (adskflex) IN: "46400INVBUN_9_0F" thomasfb@work-33
15:13:03 (adskflex) OUT: "46400INVBUN_9_0F" nicholascg@work-32
15:19:55 (adskflex) OUT: "46400INVBUN_9_0F" thomasfb@work-33
15:22:58 (adskflex) OUT: "46400INVBUN_9_0F" toddpk@work-29
15:30:01 (adskflex) IN: "46400INVBUN_9_0F" nicholascg@work-32
15:35:28 (lmgrd) TIMESTAMP 8/2/2005
15:48:37 (adskflex) IN: "46400INVBUN_9_0F" toddpk@work-29 (INACTIVE)
16:19:41 (adskflex) IN: "46400INVBUN_9_0F" travisjb@WORK-42 (INACTIVE)
16:34:28 (adskflex) IN: "46400INVBUN_9_0F" nicholascg@work-32
16:38:50 (adskflex) IN: "46400INVBUN_9_0F" kathleens@WORK-41
16:58:36 (adskflex) IN: "46400INVBUN_9_0F" terryms@work-37
17:01:33 (adskflex) IN: "46400INVBUN_9_0F" toddpk@work-29
Message 10 of 12
I need some help by establishing the TIMEOUT option in network
installation of Autodesk products. It is easy to understand how to create
the Option file, but I don't understand how to implement the option
directory in license file. Could you please send me an example of how to
do this. In manual it looks like this:
VENDOR sampled /etc/sampled
[options=]/sample_app/sampled/licenses/sampled.opt ==> I don't
understand it....
Thank you for your help.
Best regards,
Sebastjan
Message 11 of 12
TravisNave
It is easier than that.
Open notepad. Type the following:
TIMEOUTALL 900
Save the file in the same directory as your license .lic file and call it adskflex.opt.
Open LMTOOLS. Go to the Stop/Start/Reread tab and reread the license file. This will put the options file you just saved into effect. You can verify it in the debug log file.
Note: The file must be named exactly adskflex.opt. When saving from notepad, make sure it doesn't accidentally put a .txt at the end (i.e. adskflex.opt.txt) and especially if you have file extensions turned off. It also must be placed exactly in the same directory as your license file to work. The 900 is in seconds and is the lowest number you can use (15 mins.) You can change it to whatever else you want.
Good luck.
Autodesk Forums:
Message 12 of 12
TravisNave
In fact, I will just attach the file now.
Unzip and put it in the default license location of C:\Program Files\Autoesk Network License Manager\License
(unless your .lic file is located elsewhere, of course.)
Autodesk Forums:
Administrator Productivity
