Installation & Licensing
License server 32bit and 64bit on same machine
10 REPLIES 10
Message 1 of 11
aidasalminas
813 Views, 10 Replies
Hi eweryone,
we have 2 network licenses of AutoCAD Civil 3D 2012. There are users witch uses 32bit and 64bit OS, cal i place deploy for both type of OS on same machine ?
10 REPLIES 10
Message 2 of 11
DarrenP
in reply to: aidasalminas
no you can't
its 64 bit for the 64 bit OS
32 bit for the 32 bit OS
DarrenP
Message 3 of 11
TravisNave
Darren is right.  You cannot install a 32-bit version on a 64-bit machine.  However, you can create just the deployment installation files and keep both installations on your single server.  But you will have to deploy to the correct machines.
The license manager itself doesn't care which version is run as the license is platform independent.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 11
asquillacioti
in reply to: TravisNave
Can you explain to me how you load deployment installation files?
I am using Windows 7 64bit with Autocad 2012 32bit.
Message 5 of 11
TravisNave
in reply to: asquillacioti
You cannot deploy 32-bit AutoCAD to a 64-bit workstation.  You will need to deploy the 64-bit installer.
Autodesk Forums:
Message 6 of 11
oknamo
Is Civil 3D network license for 32 bit different from 64 bit. We have a windows 2003 license server for Autocad civil 3D and we have Civl 3D 32bit software on several windows xp workstations, however some of us are getting windows 7 64bit OS with civil 3D 64 bit software installed. Do we need to have an another license server for this software to work?
Message 7 of 11
TravisNave
in reply to: oknamo
No.  The CPU architecture is irrelevant to licensing.  You're probably experiencing a different network error.
Autodesk Forums:
Message 8 of 11
DarrenP
autodesk doesn't sell their products that way
you should be fine with the license file that you currently have
DarrenP
Message 9 of 11
DarrenP
in reply to: DarrenP
what error are you getting?
DarrenP
Message 10 of 11
oknamo
I was asked by the IT people If we need another license server. By opinons I gathered in this group we don't need to do anything but to install the software and make the connection with our existing license server.
Thanks everyone.
Message 11 of 11
TravisNave
in reply to: oknamo
That is the correct conclusion.  Smiley Very Happy
Autodesk Forums:
Administrator Productivity
