A few thoughts...
If he checked out the license while logged in as DOMAIN\USERNAME, then in
order to return the license, he has to be logged into windows exactly the
same way. If he logs in as LOCALPC\USERNAME, I don't think he would be
able to return the license. The borrowed license is stored per-user, not
per-machine.
If you have more than one license server, the return process could be
failing if it tries to return it to the wrong license server. Look up the
ADSKFLEX_LICENSE_FILE environment variable on the Support site. There is
also a corresponding registry key with the same name... Just set BOTH of
them to the server that has him listed as Lingering.
If the user has decided that he really, really likes a slow system with
pop-up ads, it could be that he installed some spyware, which could be
preventing the license from being returned.
Finally, I guess you could go with the brute force method.... Just delete:
(on the client)
HKEY_CURRENT_USER\Software\FLEXlm License Manager\Borrow
When you start cad again, it wont know that you have a borrowed license, and
get a real license again. Then you should be able to re-borrow it.
Chris
wrote in message news:5074852@discussion.autodesk.com...
Yes. One more idea. How long is he going to be out of the country AFTER
February 18th?
I've had somebody in this situation before, and I was able to provide them a
registry change that allowed them to run their AutoCAD as a 30-day trial
while the license manager was unavailable.
If that doesn't sound like a good idea, run his clock forward to Feb 19th
and expire the license. Stop and start the license server to clear it, and
recheck it out for whenever he needs it for.
The keep alive function of AutoCAD will allow the program to stay active for
about 6 minutes if the LM goes down. So don't worry about your other users
elsewhere. Being it only takes a few seconds to stop and start the service,
they will never know the difference.
