Installation & Licensing
License problem in GUI mode
10 REPLIES 10
Message 1 of 11
kent_2010
19099 Views, 10 Replies
Hi
Can some one help me??
 When I try to start Maya 2011 Trial I get this message
License problem in GUI mode launch dialog message
License method:
Can't determine license method
Product choice:
can't determine product choice
License file override:
environment variable MAYA_ALT_EN is not set
I used Windows XP service pack 2 64 bit
I have a Maya 8.5 installed on the computer.
I can see that Google have 4000 hits about ''Maya License problem in GUI mode''
but no good solutions
Thank you
Kent
10 REPLIES 10
Message 2 of 11
hashim.mundol
in reply to: kent_2010
hi
Follwing thread has some pointers to similar issue.
http://forums.autodesk.com/t5/Installation-Licensing/Maya-2011-Trial-Installation-Error/m-p/2675334/...
Since you have Maya 8.5, please pay attention to the ENv. Variables when changed. it might effect both the installation.
Best Regards
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 11
kent_2010
in reply to: hashim.mundol
Hi Hasim
and thanks for the quick respond
first i have try to delet this folder C😕Program Files\Autodesk\Maya2011\adlm
and restart.
 then I have try to delete this C😕Program Files\Common Files\Autodesk Shared\AdLM
and restart.
Then I have deletet the first line in License.env
MAYA_LICENSE=unlimited
MAYA_LICENSE_METHOD=network
-no dot ind the end.
Still non of the solutions can start the program.
kent.
ps I will be back on a weeks time.
Message 4 of 11
kent_2010
Problem solved
Ok here is what I did
Go to Control panel find system icon and activated it
go to advance and enverironment Variables
scroll down to maya-location
tast edit
and the new variable value is
C:\Autodesk\maya2011
or what ever location your Maya 2011 is on.
hope this will help some.
kent
Message 5 of 11
chatie
Still not working with me.
Please Help!
Message 6 of 11
gooorylan
just paste this inside maya environment file in folder    C:\Program Files\Autodesk\Maya2013\bin
MAYA_LICENSE_METHOD=standalone
open that file by wordad and add this string:  MAYA_LICENSE=unlimited
Message 7 of 11
gooorylan
open that file by wordpad and add this string:  MAYA_LICENSE=unlimited
after that the error will not appear just activation window wil be
Tags (1)
Message 8 of 11
gooorylan
Message 9 of 11
did these and NOTHING changed :SS
Message 10 of 11
HI!
 Ok! This Solution must work!
Here are three options that I have: Only Windows Sorry for other OS.
1. Re-install it  or repair it(Control Panel - Double Click on Maya - and then click repair)
2. Repair it( Control Panel - Double Click on Maya - and then click repair)
3. Uninstall it ( control panel- program (uninstall programs) and then uninstall it.- after that go to:C:\Program Files\Autodesk or C:\Program Files (x86)\Autodesk / the place where you saved or installed Maya, Depending on your bit(version) and delete the files such as Maya. And then install  egg.install.exe <the software that you downloaded {Maya}>.
Note:!!!!! If your serial number and product key will work again!!!!! So I suggest that if you don't remember don't think about it!
And also if you are a student you can get student account and download it and get the software for free.
Message 11 of 11
ughighuc
Just re-install your license.
Assuming your on WinVista/7/8...:
1) Hit the start button. Type "services.msc" and run it.
2) In Services, right-click "FLEXnet Licensing" and click "Stop".
3) Hit the start button again. Type "taskmgr.exe"
4) In the processes tab, look for "LMU.EXE". If you see it, right-click it and select "End Process".
5) Open an explorer window (or go to "My Computer"). In the address bar, type "C:\ProgramData"
6) Delete the "FLEXnet" folder completely.
7) Relaunch Maya. It will have you re-activate.
Administrator Productivity
