Installation & Licensing
Active Member
wildcat6110
Message 1 of 10 (259 Views)
license policy for render server
259 Views, 9 Replies
03-28-2013 05:14 AM
HI
I got several questions for maya and max license policy
on render server.
If I have 12 render servers (these machine are only just for rendering)
do i have to purchase 12 3DSmax and Maya ?
or is there any other licensing options for render server?
and that license policy is world common?
Thank you.
Active Member
wildcat6110
Message 2 of 10 (235 Views)
Re: license policy for render server
03-28-2013 07:07 AM in reply to: wildcat6110
I mean...that license policy is applied worldwide? Thank you.
TravisNave
Message 3 of 10 (222 Views)
03-28-2013 08:32 AM in reply to: wildcat6110
Previous policy has always been that render slaves do not require additional licensing.  I do not believe that has changed, but you may be able to verify that in the license agreement.
Active Member
wildcat6110
Message 4 of 10 (216 Views)
03-28-2013 08:53 AM in reply to: wildcat6110
Thank you for your rapid answer.
There is One more thing that I want to know.
Is That license policy applied worldwide?
(for Japan,Africa,korea...?etc)
Thank you again..
TravisNave
Message 5 of 10 (213 Views)
03-28-2013 09:01 AM in reply to: wildcat6110
I would suspect so.  Autodesk does offer global licensing.  If you are running in different territories, you will want to use Global or licensing from each respective region.  You cannot run licensing from one territory into another.
Active Member
wildcat6110
Message 6 of 10 (208 Views)
03-28-2013 09:38 AM in reply to: TravisNave
I Know that I can't run licensing from one territory into another country.
My question is...
Is it possible that korean sellers have diffent license policy for render farm?
Some sellers said that I should buy licenses for ALL render servers.
Is it really necessary?
Thank you so much.
TravisNave
Message 7 of 10 (195 Views)
03-28-2013 09:50 AM in reply to: wildcat6110
Sounds like they want your money.  Is it possible that different territories have different rules on this?  Yes.  Likely?  Probably not.  Render farming does not require additional licenses.  Launching and modeling in the application does.
Active Member
wildcat6110
Message 8 of 10 (189 Views)
03-28-2013 09:54 AM in reply to: TravisNave
Thank you soooooo much !!!
TravisNave
Message 9 of 10 (186 Views)
03-28-2013 10:02 AM in reply to: wildcat6110
Active Member
wildcat6110
Message 10 of 10 (183 Views)
03-28-2013 10:10 AM in reply to: TravisNave
Thank you again..
I already searched that document.
However they said that "IF WE SAY SO"
that is license policy for render farm in this nation.
