Installation & Licensing
License Mnager Question
4 REPLIES 4
194 Views, 4 Replies
This may be a silly question, so
please forgive my ignorance. I am new to the Network Licensing for AutoCAD.
We have a server that is our License Server. I want to monitor and control the connections from my worstation without having to log on to the server directly. Can that be done with LMTOOLS?
Thanks!
4 REPLIES 4
TravisNave
Yes.
Install LMTOOLS on your machine. Connect using License File and point to servername@27000.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Awesome.
I tried that, but came up empty... But it did give me something to go on.
I ended up installing the LMTOOLS, setting a LM_LICENSE_FILE environment variable as '27000@servername', and then launching the utility.
At that point, I can choose 'Configuration using License File' and go to my server status tab and do a succesful Inquiry.
Thanks or the help!
TravisNave
Yeah, that is what I meant. My train of thought derailed. My bad. 27000@servername. Oops.
Autodesk Forums:
For a cheap monitor, I created a batch file like this:
\\licenseserver\flexfile\lmutil.exe lmstat -c \\licensesever\flexfile\license -A >c:\temp.txt
type c:\temp.txt
pause
This opens a command window and shows me the activity going on for all licenses (I modified the command shell to get a larger window). I have an icon in my tray I just click on to run the bat file. Cheap and dirty.
Administrator Productivity
