I have just deployed a copy of the Infrastructure Design Suite Premium, install went well no problems. Went to autodesk and got the license file and updated the server with the new file. Now I can run the 2012 IDS but the other 6 copys of Civil3d 2011 version will not obtain a license file. So I went and reactivate the Civil3d and got another license file, now the Civil3d works but not the IDS. It seems to be either or. Any ideas? I am attaching the error message.
Solved by DarrenP. Go to Solution.
do the license files have a package statement in them?
run it through www.licenseparser.com to be certain
DarrenP
Yes it does, I will attach them for you to look at.
i think i know what the problem is
i ran into this issue with some of the other suites
what the workaround is to generate both license files on the same day and combine them
i agree you shouldn't have to do this but this is what autodesk said to do
DarrenP
yes just copy from the package statement all the way where it says increment ( not increment plist) and paste into the other license file
it doesn't matter which license file gets copy/pasted
DarrenP
there should only be one of these in the license file: increment plist and the
SERVER Servername MAC Address
USE_SERVER
VENDOR adskflex port=2080
DarrenP
Ok looks like the site is down for maint untill tomorrow, I will try again then, Thanks.
I don't understand, why is it showing the following error message, " The software license check out failed; error 20" (attached image). I tried different ways, by deleting autodesk files, FLEXnet files, uninstall-install 5 times. But not way it does work. It shows repeatedly. Would you please give me any solutions to this problem?
Regards
Aasif Ridwan
