Is there any chance to get license lic file in one clear structure like example below?
We still use 2005 in some cases because of using add-in to PDMS. If we can obtain license.lic file in such clear look we will have guarantee to not run more than 34 seats of different versions. Now when 2005 is with other code and increment we can run more than 34 seats but this is not floating license advantage (I mean install on every need workstation but can run only as many as purchesed).
Example:
SERVER srvname srv-mac
USE_SERVER
VENDOR adskflex port=2080
PACKAGE xxxxxACD_F adskflex 1.000 COMPONENTS=" \
xxxxxACD_2012_ \
xxxxxACD_2011_ \
xxxxxACD_2010_ \
xxxxxACD_2009_ \
xxxxxACD_2008_ \
xxxxxACD_2007_ \
xxxxxACD_2006_ \
xxxxxACD_2005_ \
OPTIONS=SUITE SUPERSEDE ISSUED=13-Jan-2012 SIGN="___ xxxx___"
INCREMENT xxx00ACD_F adskflex 1.000 permanent 25 \
VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=UH \
SUITE_DUP_GROUP=UHV ISSUED=1-Jan-2012 BORROW=4320 \
SN=xxx-xxxxxxxx SIGN="___ xxxx___"
INCREMENT xxx00ACD_F adskflex 1.000 permanent 9 \
SN=xxx-xxxxxx SIGN="___ xxxx___"
it depends
are any of these on subscription?
were any of the older version upgraded to the new versions?
DarrenP
Your Subscription license can only go back 3 versions, so you won't be able to include your 2005 as part of your PACKAGE. However, you might be able to obtain an exception for previous use for a finite # of 2005 on a 13-month expiration network license that can be appended to your license file. There is no guarantee though as this product has long been retired and your lease has expired. You'll likely need to work directly with your Reseller on this issue.
