Installation & Licensing
License file issue after server restore
2 REPLIES 2
237 Views, 2 Replies
Just restored my server after a HDD failure now my inventor 6 clients aren't
happy with the license file on the server
any help appreciated
2 REPLIES 2
You need to give more information.
For example is the license service up and running?
Best Regards, Jimmy Bergmark
Owner/Senior Developer - JTB World - Software development and Consulting
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Batch script and purge) -
http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
"Barry" wrote in message
news:5311574@discussion.autodesk.com...
TravisNave
Check to make sure that the ethernet MAC address listed in the license file matches the first one listed on the System Settings tab in LMTOOLS. This is a common problem. The hostname and MAC address must match the license file. Probably should also make sure that the NLM service itself is started.
Otherwise, more information is going to be needed to resolve your issue. Server Status tab should provide some needed information. Also your debug.log file would be helpful.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
