Hello All:
Is there a way to determine what license file was being used during the period that a report log is captured? That may seem odd, but when I install a license file I ammend the file name with the date so I can be sure it is current.
If that is not possible, is there any way to determine if a license file was replaced during the reporting period?
As always, any information would be greatly appreciated. Thanks.
- KFD -
Solved by TravisNave. Go to Solution.
Unless there is a more advanced reporting from SAMreport or JTB Flexreport, I don't think so. I would recommend that in the future, though, when you update your LIC file, that you also backup your old .rl file and let it start reporting fresh.
Thanks. I did not think so, but it doesn't hurt to ask.
We currently separate our log files by month, but you definitely have a very good point.
Thanks again.
- KFD -
