Installation & Licensing
Member
silas.salazar
Message 1 of 6 (237 Views)
License export ability
237 Views, 5 Replies
04-04-2013 08:06 AM
How do I grant someone someone the ability to import a license using LTU?
Welcome to the community Silas!
It all depends on how you exported the license. From the LTU How-To
Private ExportThis is the default method and restricts the license import to your Autodesk ID to ensure it is not transferred to another person. Private exports automatically become public if not imported within 14 days.
Public ExportThis method means your license can be transferred to someone else running the same product and serial number, such as another user in the same company. To use this method, check “Make the license available as a public import”.
Please accept as a solution if this fully answers your inquiry, or reply with additional specifics as needed.
philip.s
Message 2 of 6 (224 Views)
Re: License export ability
04-04-2013 09:34 AM in reply to: silas.salazar
Philip Schmelzer
Member
silas.salazar
Message 3 of 6 (219 Views)
04-04-2013 09:53 AM in reply to: philip.s
Thanks for the response Phillip. I believe I used the public option. Will the user at the other end need some type of login to complete the import?
philip.s
Message 4 of 6 (205 Views)
04-04-2013 02:38 PM in reply to: silas.salazar
You're welcome! The other user would simply need to enter the same serial number during the installation process and then use their Autodesk ID / password to access the license via the LTU.
If nothing is showing as available, then chances are the license was privately exported (default) in which case you would want to log into the LTU on the users computer to access the license.
Philip Schmelzer
Member
silas.salazar
Message 5 of 6 (200 Views)
04-04-2013 02:47 PM in reply to: philip.s
Great, one more question (I promise). If a computer with C3D installed is being renamed should the license be exported beforehand? Thx
philip.s
Message 6 of 6 (193 Views)
04-04-2013 05:04 PM in reply to: silas.salazar
No worries / keep them coming :smileyhappy:
The computer name should not have an impact on utilizing the LTU as the system is only looking at the current status (can't export if the SN is already exported from a different machine), serial number (needs to match up with the one used on the install) and the user.
Philip Schmelzer
