Installation & Licensing
License error has occurred
1 REPLY 1
ammaurice
1782 Views, 1 Reply
I ran into an issue tonight when I tried to run Maya 2012. I got a license error that stats I have 7 days to use Maya then I will need to repair the license. I have a commercial license that I have been using on the same machine for about a year now. When I try to repair the license it takes me through the activation, however when I try to reactivate it I am given an error 10 activation limit reached.
When I try to use The license transfer utility it states that it is unavailable and in order to export license I must reactivate this product. Not sure what is going on can anybody help?
1 REPLY 1
TravisNave
in reply to: ammaurice
You just need to get a manual activation code.  You might be using a 13-month home license.  You will need to get an extension for it.
Please call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and the request code.
Autodesk Forums:
Administrator Productivity
