Installation & Licensing
License error -63.403.2 with Mudbox
6 REPLIES 6
pgibouin
598 Views, 6 Replies
I own a license for Mudbox 2014 wich was working fine on my computer. I have installed Mudbox 2015 on it with the free upgrade offer from Autodesk and from that time, I get a license error message with the code -63.403.2 each time I launch Mudbox 2014 or 2015 on my system.
I use Windows 7 64 bits.
Any idea to solve that problem ?
Pierre
6 REPLIES 6
TravisNave
in reply to: pgibouin
-63 means that you are not a license administrator.  Odd error.  Do you have appropriate rights to the licensing?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
pgibouin
in reply to: TravisNave
I received the licensing informations from Autodesk in an email, I have
bought my license last year with one year free update and I have the admin
rights on my machine locally.
I have tried to install Motion Builder in demo mode and I have noticed I get
exactly the same error with this software (even in demo mode). It seems all
Autodesk products have this kind error on my machine.
Pierre
TravisNave
Yeah, it sounds like an issue with the licensing service itself.  So it would affect all programs, I'd imagine.  Have you tried creating another test user with local admin rights and launching it from there?
Autodesk Forums:
pgibouin
Thanks for your informations, I have tried to activate "Compatibility Administrator Mode" into Windows 7 compatibilty option for Mudbox 2014 and 2015 and also Motion Builder and evrything work fine now.
This is strange because I don't remember it is necessary to give administrator rights to Autodesk apps if you are on an admin account on Windows 7.
TravisNave
Agreed.  Is your UAC still on?  Sounds like the culprit to me.  In any case, sounds like you are up and running at least.
Autodesk Forums:
pgibouin
UAC is off, well it works fine with the Administrator Mode activated on each Autodesk programm
Thanks very much for your support !
Pierre
Administrator Productivity
