put new 2015 license file into LMTools
Inventor 2014 still works
Loaded Inventor 2015, Tried to open and got this error: [0.0.0]
Solved by DarrenP. Go to Solution.
you need to be on 11.12 for 2015
also did you update your license file for 2015
DarrenP
yes I put 2015 license file into LMTools. 2014 inventor is working
Unsure how to update LMtools to 11.12
you can uninstall what you got and install the one from the 2015 install or just download from here
and just replace the .exe files with the ones from the download
first you have to stop the license manger before replacing the .exes
DarrenP
I reinstalled LM Tools
please help
Status
Flexible License Manager status on Thu 9/4/2014 07:30
[Detecting lmgrd processes...]
License server status: @ptg-niaeng.ptgroup.ptgnet.us
License file(s) on ptg-niaeng.ptgroup.ptgnet.us: C:\Program Files\Autodesk Network License Manager\2015 license.lic:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: ptg-niaeng.ptgroup.ptgnet.us
License path: @ptg-niaeng.ptgroup.ptgnet.us;
FlexNet Licensing error:-15,570
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
1st i would check to see if the license file has the correct info in it
especially the MAC address matches to what it says in flex lm
DarrenP
