Installation & Licensing
License Alert, Error [1.5.-18]
3 REPLIES 3
935 Views, 3 Replies
I have installed a new FlexLM Server v11.4 and requested a new license file from AutoDesk. On the server side everything seems to be fine:
9:36:48 (lmgrd)
9:36:48 (lmgrd) pid 2004
9:36:48 (lmgrd) Detecting other license server manager (lmgrd) processes...
9:36:48 (lmgrd) Done rereading
9:36:48 (lmgrd) FLEXnet Licensing (v11.4.100.0 build 50818 i86_n3) started on sprn (IBM PC) (7/29/2008)
9:36:48 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
9:36:48 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:36:48 (lmgrd) World Wide Web: http://www.macrovision.com
9:36:48 (lmgrd) License file(s): C:\Program Files (x86)\Autodesk Network License Manager\License\ACD2009enlicense.lic
9:36:48 (lmgrd) lmgrd tcp-port 27000
9:36:48 (lmgrd) Starting vendor daemons ...
9:36:48 (lmgrd) Starting vendor daemon at port 2080
9:36:48 (lmgrd) Using vendor daemon port 2080 specified in license file
9:36:48 (lmgrd) Started adskflex (pid 332)
9:36:49 (adskflex) FLEXnet Licensing version v11.4.100.0 build 50818 i86_n3
9:36:49 (adskflex) Server started on sprn for: 57600ACD_2009_0P
9:36:49 (adskflex) PLIST
9:36:49 (adskflex) EXTERNAL FILTERS are OFF
9:36:49 (lmgrd) adskflex using TCP-port 2080
10:30:40 (adskflex) TCP_NODELAY NOT enabled
When I try to start the client I am getting Error [1.5.-18]. Does anybody have any ideas on that?
3 REPLIES 3
Looks like a pre-release beta code.
Technically a -18 error means "License server system does not support this
feature" as if you're trying to launch a product you don't have codes for.
Either double check you've got and reread the correct license file, or else
call Autodesk and request another file. I've had this happen before. I've
also had starting and stopping the service (instead of just re-reading the
license) help this error.
Still, that product code you've cited is a beta code.
Sam Hochberg
Inventor Certified Expert
Not too bad at AutoCAD either
wrote in message news:5993309@discussion.autodesk.com...
I
Thank you very much for your response. I had to request a new license file twice and now it is working. It was indeed a license file for a pre-release version.
No problem. Learned that the hard way, myself.
Sam Hochberg
wrote in message news:6000015@discussion.autodesk.com...
version.
Administrator Productivity
