Hi, I realise this is a newbie question, I dont use Autocad Map 3D but I work in support and have to install etc I was able to export the licence via the LTU with the following steps
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9243099
This works fine for exporting with the register hotfix as I got the no internet dialog when doing so, I followed these steps
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13589717&linkID=9240618
But when i went to new machine, it didnt work, I still receive no internet connection on import licence , it doesnt get me to signin, any ideas, do i need a new licence altogether??
Thanks in advance...
Have you tried a second Windows-user-account? If possible that has admin-rights, Firewall disabled, Antivirus disabled, UAC disabled?
- alfred -
Have you tried simply activating? You can get an activation code manually, if necessary.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
