Installation & Licensing
Licence transfer utility does not recognise internet connection
2 REPLIES 2
BillFitzgerald12345
512 Views, 2 Replies
Hi, I realise this is a newbie question, I dont use Autocad Map 3D but I work in support and have to install etc I was able to export the licence via the LTU with the following steps
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9243099
This works fine for exporting with the register hotfix as I got the no internet dialog when doing so, I followed these steps
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13589717&linkID=9240618
But when i went to new machine, it didnt work, I still receive no internet connection on import licence , it doesnt get me to signin, any ideas, do i need a new licence altogether??
Thanks in advance...
2 REPLIES 2
Have you tried a second Windows-user-account? If possible that has admin-rights, Firewall disabled, Antivirus disabled, UAC disabled?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Have you tried simply activating?  You can get an activation code manually, if necessary.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
Autodesk Forums:
Administrator Productivity
