Installation & Licensing
Licence server to another domain
2 REPLIES 2
mako68
516 Views, 2 Replies
Customer has moved licence server and user workstations to new domain. The user profiles are still on the old domain. Now Autodesk Products (AutoCAD and Inventor) are asking the licence server every time when started....
What could cause this..?
mako
2 REPLIES 2
Darin.Green
in reply to: mako68
Compare the MAC address in the license file with the server to see if they match. If they're different, you'll need to obtain a new license file from Autodesk.
If this information was helpful, please consider using the Accept Solution
TravisNave
in reply to: mako68
Domain changes can sometimes cause some weird cache issues.  Make sure that the NLM is running on the server still and handing out licenses.
The clients need to be able to PING the server and obtain the correct IPv4 address.  Then verify connectivity thru the firewall (as domain changes affects firewall settings) to make sure you can get to http://servername:2080 and http://servername:27000 in Internet Explorer.
And then, make sure the ADSKFLEX_LICENSE_FILE is set.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
