Hola agradeceria puedan ayudarme con el error que esta generando la activacion de licencia de mi cliente.
adjunto jpg.
mil gracias
I think I have your case via Support. You will need to add Everyone to permissions to the following folder:
C:\Program Files\Common Files\Autodesk Shared
http://forums.autodesk.com/autodesk/attachments/autodesk/24/49646/1/everyone.zip
Also, I would remove IE9 is possible.
