Using Microstation SE and V8i Select Series 3. When exporting a Microstation file from either version. I have noticed in the AutoDesk DWG TrueView 2015, the architect dimension slash will remain visible when turning off a layer associated with the dimension. Is this a bug? I have attached a screenshot jpg file, with a orange circle with MS Paint to locate dimension slashes drawn from export from Microstation SE application. Also, attached a second attachement with the export from Microstation V8i.
