Installation & Licensing
Latest verion of lmtools ipv4 displaying ipv6 address
3 REPLIES 3
2287 Views, 3 Replies
I am trying to license the Autodesk 2015 Entertainment Suite via network licensing, but cannot get the products to get a license.  Error 20.  What's interesting, I installed ipv4 32 bit version but when I perform a status enquiry I am getting an ipv6 address, though the 2008 R2 server has an ipv4 address.
I don't know if this is the problem, but what can I do to get lmtools to use the ipv4 address.
3 REPLIES 3
TravisNave
There is no such thing as an IPv4 vs IPv6 of the NLM (regardless of what Autodesk links.)  They are all the same.  The software vendor does not differentiate.  What I usually do is uncheck IPv6 on the server, then modify the hosts file on both the server and the client to point the netBIOS name to the IPv4 address.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Autodesk Forums:
in reply to: TravisNave
Thanks, I found that post earlier which gave me the solution.  The link below is where I downloaded lmtools from and is the reason I refer to an ipv4 or ipv6 version of the tool.  A little confusing Smiley Embarassed
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Latest-...
TravisNave
Yeah, they make it confusing. I wish they wouldn't do that to y'all. Hope
you're all up and running now.
Autodesk Forums:
Administrator Productivity
