Hi Franck,
Thank you for reply. But it still doesn't work. Here's what I did:
1. I shut down the laptop and removed the laptop off the docking station.
2. Connected directly to the onboard NIC, started the laptop using the
battery and borrowed a license.
3. Shut down the laptop, removed the network cable.
4. Started the laptop again using battery power.
Results - could not find the borrowed license.
Then, I just plugged in the AC adapter and the laptop found the AutoCAD
license.
I'm sure it's not the MAC address. Any other suggestions?
Dennis
"Franck Hervet"
wrote in message
news:6091828@discussion.autodesk.com...
Borrow a licence when you are disconnect of the docking station and
connected to the network.
When you borrow an AutoCAD license, it makes a difference between the
network card of the laptop nd the network card of the docking station.
This is not an AutoCAD problem.
It works like this.
you have two network card :
one in the laptop.
another in the docking station.
They have different mac adress.
Franck Hervet
www.aricad.fr
"Dennis S. Nunes" a écrit dans le
message de groupe de discussion : 6091789@discussion.autodesk.com...
> We have a IBM ThinkPad T60 laptop that when connected to our network, can
> borrow a license for AutoCAD 2008 with no problems. When we shut the
> laptop down, disconnect from its docking station and bring it up on
> "battery only," AutoCAD 2008 cannot find the borrowed license and we
> receive the dialog box to specify the license file.
> However, if we connect the laptop to it's AC power supply unit, AutoCAD
> see the borrowed license and works fine. Once we are able to get AutoCAD
> started in this manner, we can disconnect the power supply unit and work
> off the battery. We can even close AutoCAD and start it again and it will
> see the borrowed license with no problems. But once we turn the laptop
> off, we can no longer use the borrowed license unless the AC power supply
> cord is connected or we are connected to the docking station.
> Any suggestions?
> Dennis
