Installation & Licensing
Active Member
gcurtis68
Message 1 of 11 (591 Views)
Laptop copy of Inventor 2009 Pro not retaining activation.
591 Views, 10 Replies
12-11-2012 10:40 AM
We have a copy of Inventor 2009 Pro installed and activated on a Win XP X64 desktop with no issues.  Put an additional "away from usual work location" installation on my boss' Win 7 laptop and it indicated that it had activated successfully.  However, it would seem that it is not retaining that activation as it has periodically resubmitted activation requests until recently when it is now infoming us that we have reached our activation limit.  Can anyone offer any ideas as to why this is happening, suggestions, fixes, etc?  Thanks in advance.
Gary
My apologies Gary, as that is the location for 2010-2013 products.
For 2009 the adskflex_*_tsf.data file should be in the following:
XP
C:\Documents and Settings\All Users\Application Data\Autodesk\Software Licenses
Vista/Windows 7
C:\Users\All Users\Autodesk\Software Licenses
If that doesn't work, you may want to consider running the software in XP / Compatability Mode to see if it clears up the issue (as previously mentioned, Inventor 2009 is not supported on Windows 7).
Hope that helps!
Active Member
gcurtis68
Message 2 of 11 (580 Views)
Re: Laptop copy of Inventor 2009 Pro not retaining activation.
12-11-2012 12:50 PM in reply to: gcurtis68
Somebody?  Anybody?  Any help would be really appreciated.
Thanks.
philip.s
Message 3 of 11 (576 Views)
12-11-2012 02:10 PM in reply to: gcurtis68
Hello Gary,
I'm not 100% that this will work, but can you rename the following file by adding a .bak extension at the end of the filename.
Windows XP
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*_tsf.data
Vista/Windows 7
C:\ProgramData\FLEXnet\adskflex_*_tsf.data
When you restart Inventor and it should automatically re-register and as a result a new adskflex_*_tsf.data file will be created and it will start up as expected.
I also wanted to point out that Inventor 2009 is not officially supported to run in Windows 7, and as such functionality may or may not be impaired.
Philip Schmelzer
Active Member
gcurtis68
Message 4 of 11 (573 Views)
12-11-2012 02:15 PM in reply to: philip.s
Hi Philip,
I will give it a try and get back to you.
One question though:  Will I need to contact Autodesk first and have them reset the activation limit after I make the suggested change but before I restart Inventor?
Gary
philip.s
Message 5 of 11 (570 Views)
12-11-2012 02:21 PM in reply to: gcurtis68
Sounds good and yes, if you're still receiving the activation limit reached error, please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request code, or contact our License Assistance team for an activation code.
Philip Schmelzer
Active Member
gcurtis68
Message 6 of 11 (564 Views)
12-11-2012 03:05 PM in reply to: philip.s
Looked in C:\ProgramData and found no FLEXnet directory.  Did a drive-wide search for adskflex_*_tsf.data and there were no matches.
philip.s
Message 7 of 11 (554 Views)
12-11-2012 04:21 PM in reply to: gcurtis68
XP
Vista/Windows 7
Hope that helps!
Philip Schmelzer
Active Member
gcurtis68
Message 8 of 11 (533 Views)
12-12-2012 12:35 PM in reply to: philip.s
Philip,
There are only two files in C:\Users\All Users\Autodesk\Software Licenses.  Neither match the adskflex_*_tsf.data mask that you provided.  They are named B54A5000.dat and B55DF000.dat.  Please advise...
Gary
philip.s
Message 9 of 11 (518 Views)
12-12-2012 04:41 PM in reply to: gcurtis68
Thanks for confirming. Try deleting all of the .dat files from that folder and restarting Inventor. Once again there is no guarantee that it will work as it's not supported to run on Windows 7.
Philip Schmelzer
Active Member
gcurtis68
Message 10 of 11 (503 Views)
12-13-2012 10:17 AM in reply to: philip.s
Philip,
Deleted license files, restarted inventor and it seemed to recognize that the license files were absent thereby initiating another activation dialog.  As already expected, it responded with the "activation limit reached" error message.  Per your earlier instructions, I have already sent you a private message containing the serial and request code.  Thanks in advance for your time.
Gary
