Installation & Licensing
Lab Environment With Multiple Users Having Issues With Windows 7
4 REPLIES 4
achapin
637 Views, 4 Replies
We recently upgraded our CAD lab to Windows 7 and have come across some issues.  We have a multi user classroom.  Before W7 I would install the software using the local admin account, make the customizations I needed then copy the local admin profile to the default user profile.  The students would then get all the customizations I made when they log on.
Windows 7 is very different in the way it handles profiles.  I have tried everything I can think of and still not all of the customizations, file paths, etc. are holding.  I've tried using sysprep, tried using Windows Enabler and tired a straight data copy.
For instance, right now we can't run Inventor because the default profile didn't hold the location of the Undo directory.  Since these things are per-user changes and we have hundreds of students it is impossible to change them for every user.
Is anyone else running the Education Master Suite 2010 and/or 2012 on Windows 7 in a lab environment like this?  Has anyone had these issues and found a way to deal with them?
4 REPLIES 4
david.lau
in reply to: achapin
We get this one a lot for Inventor.  Please check out this post:
http://forums.autodesk.com/t5/Autodesk-Inventor/Imaging-Inventor-and-Current-Undo-Folder/td-p/276233...
David Lau
achapin
Thanks for the info, but the link only applies to XP.  I've been doing that very thing up until this year when we migrated to Windows 7.
achapin
A little more info...I need a way for these changes to be in place when the user sits down.  We have several hundred students and having them all run a command or xml file or regedit isn't feasable.  Additionally, our computers are frozen with Faronics DeepFreeze so any changes a user might make will revert overnight when the comptuers reboot.
david.lau
I think you are just customizing Inventor with a non profile specific folder.  i.e. C:\InventorTemp.  You will  need to create a C:\InventorTemp folder on your Windows 7 computer.
David Lau
Administrator Productivity
