Having just purchased a yearly subscription for AutoCad Lt 2015, installation went smoothly. Product activated.
Can anyone tell me why i receive an email from Autodesk congratulating me on registering the program, every time i open the program?
I notice that everytime i open the program it checks the license and updates the file where it is stored this can`t be right?
Also if i am offline the program comes up with a manual activation option stating the license has been modified!
The program will not run offline without first entering the autorisation code.
What is going on. I have installed many stand alone versions of Autoad LT and never had any problems.
Please can some one help.
Thanks.
It seems like there is something running on your machine that is invalidating the license. Do you have some sort of Windows settings freeze program, a daily restore, or other similar time-related program? Also could be a roaming profile or other remote server folder redirect problem. Something is different about your setup and you need to narrow it down.
Hi Travis
Having had the initial problems I decided to start from scratch.
I have installed it on a clean installed windows 7 32bit system, no other programs installed. Only windows updates have been allowed.
But still have exactly the same issue. Very confused.
Ta
Hadn't seen this post, and posted pretty much the same message this morning! LIke you say I get a new email with activation code every time I start up Max.
Annoying, but the fact max works, I guess I will just have to put up with it until anyone can advise on what's going on!
Richard
