I own Inventor Series 11. 6 Months ago I updated my desktop to Windows 7. I was given a new Serial number. The install went fine. i was also directed on how to install Vault 5 server since all of my files were stored there.
Recently, my laptop was stolen. The only replacements available are windows 8 machines. Liscensing provided me the necessary information to install the 64 bit version of Inventor 2011. I need to install Vault 5 Server to replicate my desktop. I syncronize the 2 machines when I travel. I am being told by liscensing that my Series 11 has been upgraded to Suite 11 and that Suite 11 doesn't have Vault 5. My issue is that , without Vault 5 Server I will not be able to use my laptop and i have 10+ years of vaulted Data.
Can someone please help me? The liscensig and activation department sent me to the subscription center. I am not on subscription anymore as we are a very small company that is struggling so I have no way of getting assistance. Please help.
George
I am confused... are you using Vault 5.0 and Inventor 11, which came out in 2006.....
or, are you using Inventor 2011. There is about 5 years between these two releases.
In Inventor, go to help>about and paste a screen capture (might want to blot out the serial number).
I am using Inventor 2011 with Service Pack 2 Installed. (64 Bit)
When I open the Vault It tells me it is Vault 2011. The original Install disks for the Vault were Labeled Vault 5. They were included in my original Inventor Series 11. I guess what I need is a way to Install Vault 2011 on my Laptop.
Sorry for the confusion but this has been very time consuming and confusing for me as well.
When I open the Vault It tells me it is Vault 2011. ........ I guess what I need is a way to Install Vault 2011 on my Laptop.
Where do you have "It" installed now... on a different computer... or on a server?
Even if you did install Vault Basic Client 2011 on your laptop, you will also have to install the Vault Client 2011 somewhere.... either on the laptop or on a server that its connected to. Still a little confused about what you "need". Are you missing Vault Client or Vault Server?
As I review this I realize I have not been complete on my issue.
I am a stand alone user. I keep duplicate environments, 1 on my desktop and 1 on my laptop, as I travel often. I set each machine up as a Vault Server. I syncronize the 2 machines regularly so I can work from home in the same environment. I do this by backing up the vault and restoring it on the other machine. I then syncronize the working directory using beyond compare.
I hope this helps.
thanks
In order to use your vault 5 date with Vault server 2011, it will have to be migrated from Vault 5 to Vault 2011. Did AD tell you that this migration path was supported?
There were several Vault versions between these two. Normally, you can jump a couple releases, but migrating between versions that are that far apart may cause problems. Then again, it might work just fine, I am just not sure.
