Installation & Licensing
Issues with downloading and installing autodesk inventor 2010 student
4 REPLIES 4
gatopaitelepe
528 Views, 4 Replies
I have tried to download Autodesk Inventor 2010, part one downloads fine but twice i have tried to download part 2 and it keeps saying download failed.  When i tried to install part 1 to see if it would work without part 2 it came up with an error message.  I am getting very frustrated as it shouldnt be this hard to download and install a program.  What am i doing wrong?
4 REPLIES 4
Hi gatopaitelepe,
Do reply back with the specific error message encountered so we can check further.
Also, when downloading do try using other browsers or the other Download Method (Download Now ; Browser Download). Do let us know if it still didn't work out for you.
Joane Bonghanoy
I have been using google Chrome, will try IE now and if the error comes up I will write it on here as I forgot what the error was. Thanks
10seghers10
in reply to: gatopaitelepe
Have tried to download inventor several times and have goten this same error message?
I have downloaded Autocad on the same computer with no problem, is there a new inventor program I can download?
The required volume is absent
CRC failed in x86\acadm\Program Files\Autodesk\Root\Acadm\gef\Gdb\SYS\Fstn\Screw\Peculiar\Eye\NO0178.gpl
TravisNave
in reply to: 10seghers10
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
You might disable real-time virus protection while downloading.
Autodesk Forums:
Administrator Productivity
