Hello, i have been trying to install the software for around 2 weeks now to do my college work and i get the the same error message each time (Failed Failure is ignored, Result=1619). i have tried uninstalling the Microsoft Visual C++ Reditributable files (2005, 2008) and this did not work either. The full log is attached.
Thank you.
Solved by TravisNave. Go to Solution.
I found the problem to your installation:
Install Autodesk Material Library 2013 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
I have provided the solution for this recent issue here:
Good Luck!
Hi, i need some help. I have allready installed a student version of 3ds Max 2013. Unfortunately I had to delete my Operating System because of malware. Now I have done a "refreshening" of my OS but I have problems to install 3ds Max 2013 again. I donĀ“t know where I could get some help now. What should I do?Best regards.Kathy
