Installation & Licensing
Is it any issue to NOT install full standard / premium suites?
2 REPLIES 2
dst_01
327 Views, 2 Replies
Good afternoon,
I would like to know if its any issue to not install full standard / premium suites?
In Adesk premium suites I would Not like to install : electrical, 3DSMAX design, Mudbox ,
Showcase and inventor standard as I will install Inventor with routed systems.
Adesk standard suite: mainly I would like to install only :AutoCAD Mechanical & Sketchbook.
Many thanks for an answer.
Best regards
2 REPLIES 2
TravisNave
in reply to: dst_01
Of course not.  You can only install the applications in the suite that you want.  Save yourself some time and space and uncheck the applications that you don't want to install.  Good luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dst_01
in reply to: dst_01
Thanks a lot
Administrator Productivity
