Installation & Licensing
Member
dst_01
Message 1 of 3 (215 Views)
Is it any issue to NOT install full standard / premium suites?
215 Views, 2 Replies
01-26-2013 08:11 AM
Good afternoon,
I would like to know if its any issue to not install full standard / premium suites?
In Adesk premium suites I would Not like to install : electrical, 3DSMAX design, Mudbox ,
Showcase and inventor standard as I will install Inventor with routed systems.
Adesk standard suite: mainly I would like to install only :AutoCAD Mechanical & Sketchbook.
Many thanks for an answer.
Best regards
Of course not.  You can only install the applications in the suite that you want.  Save yourself some time and space and uncheck the applications that you don't want to install.  Good luck!
TravisNave
Message 2 of 3 (188 Views)
Re: Is it any issue to NOT install full standard / premium suites?
01-27-2013 12:04 PM in reply to: dst_01
Member
dst_01
Message 3 of 3 (177 Views)
01-28-2013 02:33 AM in reply to: dst_01
Thanks a lot
