Installation & Licensing
Is it any issue to NOT install full standard / premium suites?
2 REPLIES 2
333 Views, 2 Replies
Good afternoon,
I would like to know if its any issue to not install full standard / premium suites?
In Adesk premium suites I would Not like to install : electrical, 3DSMAX design, Mudbox ,
Showcase and inventor standard as I will install Inventor with routed systems.
Adesk standard suite: mainly I would like to install only :AutoCAD Mechanical & Sketchbook.
Many thanks for an answer.
Best regards
2 REPLIES 2
TravisNave
Of course not.  You can only install the applications in the suite that you want.  Save yourself some time and space and uncheck the applications that you don't want to install.  Good luck!
Autodesk Forums:
Thanks a lot
Administrator Productivity
