Hello
We are using AutoCAD Inventor LT Suite 2012 I am trying to install the Tutorial files from Autodesk Inventor Service & Support web site. I downloaded and extracted the files just like the Tutorial files intallation instructions .TXT said to but the next step says to double-click the tutorial_files.ipj file when I do this I get a message from Windows (windows can not open this file) I tryed opening Inventor 2012 LT and clicking open then browsing to the file but the file type ipj is not in the list of file type Inventor will open I clicked all file types and then clicked the file tutorial_files.ipj and Inventor 2012 LT gave me an error (failed to open document). Should Inventor 2012 LT open these files and if so how do I do it
Joe
Solved by DarrenP. Go to Solution.
inventor LT doesn't use a inventor project file like the full blown inventor
you should be able to open the tutorial files without the .ipj
DarrenP
In Inventor 2012 LT when I Click the Tutorials button it takes me to Autodesk WikiHelp Tutorials. Are these the Tutorial files you are talking about that I should be able to open and also If I upgrade to Inventor 2013 LT will I be able to use the downloaded Tutorial data set files
Thanks again
i was talking about these: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18718356
DarrenP
i can't find the 2012 files
DarrenP
I found the 2012 files and downloaded them you just cant get to them from the Tutorials button in Inventor you have to browse to them and open them that way
