Hi everyone,
I downloaded the italian version of Inventor 2014.
The name of file is: Autodesk_Inventor_2014_Ita_64bit_dlm_001_002.sfx (3,93 GB)
When I go to install it says missing files.
Where is this missing file?
Please, help me.
Thank you
Solved by asburyj. Go to Solution.
The inventor download is broken into two parts. When you choose a browser download it should start downloading both. One should end with _001_002 and the other ends with _002_002
To save you a little trouble I have generated a direct download link to that 2nd part. You can trigger the download with the link below
It works!!!
I downloaded the second file and there isn't the error message now! finally!
Thank you very much!!!
Have a good day.
similar isssue for me, with this file:
Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm_001_002.sfx.exe
But it seems (from the name at least "001_002") that it contains both parts...
The 001_002 in the file name means file 1 of 2. If you are missing part 2 you can download it from the virtual agent using the instructions posted above.
please, can you post ones again link to 002 file? The preveuse one doesnt work anymore. Thanks
You wanted the italian version like what was originally requested in the thread? If so here's a link
